64bit AIX upgrade question 2nd Post
We have 64bit AIX 5.3 & installed 6.54FP1 Notes server,It works fine.
But after upgrade 7.02 fp3 or 7.03fp1 ,The Adminp task always crash ( if rename adminp ,the server can start)
the NSD tools list “OSLockReadSem” problem but no technote result
herer is some key error message:
“directory containing adminp could not be determined”
fatal_error(signl = 1531858772, info = 0x45535d44, context = 0x45425547), line 2297 in “break.c”
.() at 0x3434
OSLockReadSem(sem = 0xd1ddf1e0), line 3164 in “ossem.c”
StaticHang = Virtual Thread [ adminp:647294: 2] (Native thread [ adminp:647294: 1]) (0x9e07e/0x2/0x1)
Is it AIX 32bit /64bit problem? or language problem ?
We have Traditional Chinese display data folder & LanguagePack installed
Thanks for your help…
