6.5.3 FP1 Installation problem
Hi everybody
I have a problem with 6.5.3 FP1 for linux, when I try to install it I just get a message that says
“Verifying the installation data, this can take several minutes”, but that´s all the installation never starts.
I have done everything that the README file says
But it does not work
Some idea?
Subject: Using a language pack?
Had some problems with 6.5.3 FP1 on a localized setup. See this:
http://www-10.lotus.com/ldd/nd6forum.nsf/ShowMyTopicsAllFlatweb/8df63467f0a3aa5685256f9b0074d21e?OpenDocument
