2nd Post - Lookup using LotusScript in Web Agent
Hello Forum, hope someone can help me with this one.
I have created a agent to do a lookup from the web but I can not get a handle on the values -
Could someone assit me in this agent.
Sub Initialize
Dim session As NotesSession
Set session = New NotesSession
Dim ldb As NotesDatabase 'Lookup up database
Dim view As NotesView ’
Dim doc As NotesDocument
Dim ldoc As NotesDocument
Dim key As String
’ Print session.UserName & “
Set ldb = New NotesDatabase(“ServerName”,“admin\myscan.nsf”)
Print " ldb is working
Set view = ldb.GetView(“(uname)”)
Print “lview is working
Set ldoc = lview.getDocumentbykey(“Troin Artis”)
If Not ldoc Is Nothing Then
Print “I got a handle on the doc
'Print "Ldoc.databasefilepath
" & ldoc.databasefilepath
Print "ldoc.GetItemValue(DatabaseFilepath)
" & ldoc.GetItemValue(“DatabaseFilepath”)
Print "Ldoc.databasefilepath(0)
" & ldoc.databasefilepath(0)
Print
Else
Print “Can not get a handle on ldoc
%REM
%END REM
Subject: 2nd Post - Lookup using LotusScript in Web Agent
I aplogize for reposting - I just figured if I had reposted I would get a response that ask me question about my code instead of how I am running the code. In any event thanks I found the answer.
My code had a typo.
Subject: RE: 2nd Post - Lookup using LotusScript in Web Agent
One of the most important questions to ask about code being run for a web application is how it is being run/called…I was not looking for a typo.
If you had run it through the debugger before posting here, you would have found the typo
I assume your problem is getting GetDocumentByKey to work? Make sure that “Troin Artis” appears in the first column of the (uname) view, and that the column is sorted. It won’t work if the column is displaying hierarchical names–you must use the Common Username.
I’ve always had trouble getting this method right, so I tend to use db.Search to create a “collection” of one document and work with that.
Note, however, that it’s not certain that your lookup datase and lookup view are being accessed successfully. Your agent is going to print “ldb is working” and “lview is working” whether those lines of code worked or not. These would be better tests:
Print ldb.Title " is assigned to ldb
Print lview.Name " is assigned to lview
What’s actually happening? Or not? And why are you re-posting this when you have a thread on the go further down?
