xPages unfortunate Esc Key hit problem
I have created a xpage application for the customer who uses it in 8.5.1 (client). I had a complaint from the customer saying unfortunately i have pressed the esc key and the whole data is lost which means notes client tab got closed without saying do u want to save data or close like that… Pls suggest me what solution i have to do in the xpage to handle it.
Subject: Resolved
Add This code in xpage source. THis client script will check for Esc key event on key press and stops the tab to close
