Hello I am trying to Display a Photo from another Document in an Xpage it works perfectly in the Web , but not in The Client. I have a Photo Document the same Database. The Photo is Attached as Rich Text Lite Thumbnail. The Document also has a field with the Attachment Name here is the Code
if(@ClientType()!=“Notes”)
var myName = rowData.getItemValueString(“UserName”);
var db = new Array(@Name(“[CN]”,@Subset(@DbName(),1))+“!!names.nsf”);
return @DbLookup(db,“($Users)”,myName,“PhotoUrl”);
} // end web
else
// Notes
var view = database.getView(“Photos”)
var doc = view.getFirstDocument()
var url= getImageHTML(doc)
return url
Builds some HTML to display the photo for a contact
function getImageHTML(doc:NotesDocument){
var files = doc.getItemValue("AttachmentNames");
var out = "";
var dbPath = getDbPath();
for (var i=0; i<files.length; i++){
if (out != "")
out += "<br />";
if (files[i].toLowerCase().indexOf(".jpg") > -1 ||
files[i].toLowerCase().indexOf(".gif") > -1 ||
files[i].toLowerCase().indexOf(".png") > -1)
out += "<img class=\"viewphoto\" src=\"" + dbPath[0] + "/xsp/.ibmmodres/domino/OpenAttachment/" + dbPath[1] + "/" +
doc.getUniversalID() + "/photo/" + escape(files[i]) + "\" />";
if (out != "")
out = "<div class=\"screenshotimage\">" + out + "</div>";
return out;
Cache the dbPath variables in an applicationScope variable
function getDbPath(){
if(isCacheInvalid("dbpathweb", 600)){
synchronized(applicationScope){
var dbPath = @Left(context.getUrl(), ".nsf") + ".nsf";
var pos = (context.isRunningContext("Notes")) ? 4 : 3;
var secondPathElements = dbPath.split("/");
var secondPath = "";
for (pos; pos<secondPathElements.length; pos++){
if (secondPath != "")
secondPath += "/";
secondPath += secondPathElements[pos];
var res:Array = new Array();
res.push(dbPath);
res.push(secondPath);
applicationScope.dbPathWeb = res;
return applicationScope.dbPathWeb;
A generic caching mechanism for each key will check to see if it is 'n' seconds
since it was last updated. Use for things that change relatively infrequently
function isCacheInvalid(key, cacheInterval){
var currentTime = new Date().getTime();
if (!applicationScope.containsKey(key + "_time")){
applicationScope.put(key + "_time", currentTime);
return true;
var diffInSecs = Math.ceil((currentTime - applicationScope.get(key + "_time")) / 1000);
if (diffInSecs < cacheInterval) {
return false;
} else {
return true;
Anybody on this?
Kind regards
Michael
