Hello,
When using a pair of Label-Value with XPages I got a problem.
I am using a formula item to populate my ComboBox. My list is retrieving from à multivalues field. It is stored like that :
premier item|1
second item|2
third item[3
It works fine when I am in edit mode. The value stored in my backend document is the Value ( 1 or 2 or 3 , etc…) . That’s ok. When I am in edit mode the associated Label is displayed.
The problem comes in read mode. The Value is displayed instead of the Label. I have the same problem with radio, list, etc…
If I hard code my list it works fine.
Thank you for your help.
