I’m trying to instantiate a Google CalenderService class via server-side javascript.
I believe I have installed the libraries correctly, but get the following error:
Script interpreter error, line=1, col=52: Object does not support instantiation com.google.gdata.calendar.CalendarService:
Here’s the code:
myService = new Packages.com.google.gdata.calendar.CalendarService();
Subject: Could you attach a sample?
Subject: I have a workaround
I had the same problem some minutes ago.
I can’t explain why this problem occurs, but you can fix it you write a public method into your scriptlibrary containing the class you want to instantiate.
This method only contains this code:
function getLib1() {
var lib1 = new libTest1();
return lib1;
So this method instantiates the class for you and returns the instance.
As I said, I don’t know why this problem occurs, but it works.
