A bug has been documented that client-side JavaScript does not execute in buttons after a Partial Update (http://www-10.lotus.com/ldd/nd85forum.nsf/5f27803bba85d8e285256bf10054620d/e63e2f01382e1539852575a700370e75?OpenDocument)
Can anyone confirm whether or not this is really fixed in the update scheduled for July?
Subject: fix really needed
Hello all,I do agree with Russel. We need this problem fixed asap. We opened a ticket about it, but got no real feedback…
it really has to be fixed.
In the meanwhile, we use the following (painful) workaround :
<xp:link id=“btnEditSave” styleClass=“button”>
<xp:label value="Enregistrer" />
</xp:link>
<xp:button id="btnEditSaveTrigger" value="Enregistrer">
<xp:eventHandler event="onclick" submit="true" refreshMode="complete">
<xp:this.action>
<xp:executeScript>
<xp:this.script><![CDATA[#{javascript:
// SERVER SIDE SCRIPTING HERE
}]]></xp:this.script>
</xp:executeScript>
</xp:this.action>
</xp:eventHandler>
</xp:button>
<xp:scriptBlock id="btnEditSaveAssociate">
<xp:this.value><![CDATA[
dojo.byId("#{id:btnEditSave}").onclick = function() {
// CLIENT SIDE SCRIPTING HERE
dojo.byId("#{id:btnEditSaveTrigger}").click();
]]></xp:this.value>
</xp:scriptBlock>
we add a onclick event handler on our button (which is a link for css needs).
This functions first executes client side code, and then clicks a hidden xpage button to trigger serverside code.
A pain to use, but it s only a workaround.
Please IBM fix this asap.
Luc
Subject: Fixed in the first 8.5.1 managed beta
Yes, the issue #PHAN7RKDER is fixed in the first 8.5.1 managed beta.It is fixed in builds with date stamps 20090510 or later.
Subject: Thank you for the update…
…it is helpful to know.
Thanks again.
