Ws.prompt problem
Hi,I had allready asked this but some change in the functionality thats why asking agaikn…
I have ws.prompt functionality in the code from which user will select rejection reasons…in this the user should be able to view/edit the choices present in the list and also able to add new choices…
I cant use ws.dialog method because the return value from ws.prompt is a string and ws.dialog returns a boolean…the string value from ws.prompt is required after wards…
how to do this??
Subject: ws.prompt problem
post the code you have so far
Subject: RE: ws.prompt problem
Code:
’ PROMPT USER TO SELECT A REJECT REASON
'Dim askme As Variant
'Dim requestdenied As String
'reason(0) = "Documentation Error(s)"
'reason(1) = "Not Needed"
'reason(2) = "Logic Error(s)"
'reason(3) = "Platform Related Issue"
'reason(4) = "Rescheduled"
'reason(5) = "Requirements Change"
'reason(6) = "Other - See Rejection Comments"
'askme = ws.Prompt(PROMPT_OKCANCELLISTMULT, _
'"Select A Reason", _
'"Select A Reason For Rejecting This Document", _
'reason(6), reason)
askme=ws.DialogBox("RejectionReason",True,True,False,False,False,"Rejection Comments")
'if askme contains "other...." then call up the RejectDialog box form to add additional information and append it to the additional information field
Forall m In askme
	If m = ("Other - See Rejection Comments")  Then
		Msgbox"Please Enter your comments in the below field"
		additionalinfo = ws.Dialogbox("RejectDialog",True,True,False,False,False,False,"Rejection Comments",)
End Forall
If askme=False Then
	Messagebox "Sorry, you must select a reason for rejecting this request", , "Reason Required"
	Exit Sub
Else
	Forall ask In askme
		asklist = asklist & ask & Chr(10)
	End Forall
'put the reject reasons in the rejectreason field to be used in views
Set item = doc.GetFirstItem( "RejectReason" )
Call item.AppendToTextList(Cstr(asklist))
' add the reject reasons to the Approval History
Set item = doc.GetFirstItem( "ApprovalHistory" )
Call item.AppendToTextList( "Version " + Cstr(uidoc.FieldGetText("DispVersionNumberRework")) + " Reason(s) Rejected:  " & Cstr(asklist))
’ PROMPT FOR ADDITIONAL INFORMATION
'Input box to get additional information
'additionalinfo = Inputbox$("Add any additional information here", "Additional Information")
’ CONFIRM REJECT
'confirmmsg% = Msgbox ("Test: last chance to cancel out of this - test  Do you wish to continue?" , 4+ 32 + 0 + 0, " Transmission")
confirmmsg% = Msgbox ("This will reject this LCN and send a notice to all the participants.  Do you wish to continue?" , 4+ 32 + 0 + 0, " Transmission")
If Not confirmmsg = 6 Then
	Exit Sub
This is the code…now this code has only 6 options which are const…i want those options to be editable…also user should be able to add new options…the 6 options one can see r Documentation Error(s),LCN Not Needed and so on…
thought you wanted to use the Prompt method. Why not use PROMPT_OKCANCELEDITCOMBO, this will allow user to select an existing value from a list or type in their own value.
Dim reason (1 To 6) As String
askme = ws.Prompt(PROMPT_OKCANCELEDITCOMBO, "Select A Reason", "Select A Reason For Rejecting This Document", reason(6), reason)
Well!! This is working…but the problem is I want user to select multiple values as rejection reasons can be multiple…and by this method user can select one value and if he wants to select one more value then he will have to type it and if user gets wrong in the spelling of the rejection reason then the caode won’t be executed as per the requirement…
I dont think anything more can be done about this…Please let me know if something more is possible…
nyways…thanks for the help…at least because of your suggestion i was able to complete 70% of the work…
maybe have another choice of “enter new reason” so user can choose:
reason 1
reason 2
enter new reason
then check the values returned and if “enter new reason” is a choice then give them another prompt where they can enter their new choice. I know it’s 2 prompts but maybe this will work for you.
From the Designer Help…
Variant of type integer	for PROMPT_OK, PROMPT_YESNO, PROMPT_YESNOCANCEL
Variant of type string	for PROMPT_OKCANCELEDIT, PROMPT_OKCANCELLIST, PROMPT_OKCANCELCOMBO, PROMPT_OKCANCELEDITCOMBO, and PROMPT_PASSWORD
Variant Array 	for PROMPT_OKCANCELLISTMULT
Type% PROMPT_OK always returns 1.
For type% PROMPT_YESNO, returns 1 if you press Yes. If you press No, returns 0. For type% PROMPT_YESNOCANCEL, returns -1 if you select Cancel. For all other type%s the return value is a variant containing a string array if you press OK, and EMPTY if you press Cancel.
I want to provide the facility of editing the list of choices…I mean to say allow user to provide external values. This is present in the dialog list field where one can add additonal extra values not in the field.
The use a dialog box!!
You can call a Ws.DialogBox using a document other than the active one. Then just get the value from that document
eg: Ws.DialogBox(“(DialogBoxName)”, true, true, false, false, false, false, “Title”, tempDoc)
value=tempDoc.WhateverFieldName(0)
