Works IDVault with Roaming?
Dear
i will activate ID Vault and i have some roaming users. They have insert the id in the personal names.nsf.
Works IDVault wiht roaming or are there some problems ?
Max
Subject: Yes
Refer to the ID Vault FAQ:
http://publib.boulder.ibm.com/infocenter/domhelp/v8r0/index.jsp?topic=/com.ibm.help.domino.admin85.doc/DOC/H_NOTES_ID_VAULT_FAQS_OVER.html
Subject: notes basic
Do I have to use Notes basic version to get roaming work?
Subject: Not with ND8.5.x
ND8.5 provides roaming for the standard clientND8.5.1 provides workspace roaming and file server roaming for Linux and Mac clients
