Window Title using Calendar Group
Hi guys…
I have a problem with group calendars. the secretary has 3 group calendars, each with its name for example Members, Partners, Employees, but when she opens them all three have the window title “Group Calendar”. ;it would be nice that each screen had the title of Group Calendar.
when then click in the detail of a member, the title becomes a generic “Untitled”
very irritating
thank you in advance for a reply
Subject: Re: Window Title using Calendar Group
Hello Andrea!
This issue is documented by IBM under SPR # JKEY8P5HB3 / APAR LO65830:
LO65830: GROUP CALENDAR TAB IS WHEN CREATED
LO65830: GROUP CALENDAR TAB IS <UNTITLED> WHEN CREATED http://www-01.ibm.com/support/docview.wss?uid=swg1LO65830
Unfortunately, there is no plans to fix it for while.
It is under investigation/analysis from our Development Teams to be implemented/fixed on future releases.
Best Regards!
Rodrigo San Vicente
