Hi, for some reason (that I don’t know), danish characters æ, ø and å are not showing right in the internet. This is hapeening when I enter them trough internet explorer. When I enter them trough Notes there is no problem
Any idea ?
Thanks in advance
Paulo
Subject: Why æ, ø and å are not showing right in internet side ???
Hi, In ur form property on the second tab set on web access charector set set to Unicode(UTF8) it will solve ur problem.
regds
soma
Subject: RE: Why æ, ø and å are not showing right in internet side ???
Thanks for the help but it was not enough. Should I change anything else ? And in the internet explorer ?
Thanks in advance
Paulo
OK, I found it, just change also in the internet side view/encoding to Unicode UTF-8
Thanks a lot for all your help
