Whitelisting - Partial Solution - Need help finishing please
Hi all. After reading tons of posts in this forum and other notes forums about blacklisting, it seems that whitelisting is a much better fit for our company. I found a couple of great threads with some posted code that I took and modified. The first thread was here → http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/6e4f2e6aa89587c685256d420050feb8?OpenDocument Instead of looking at the RBL tag and determining if it’s SPAM that way, I reversed the logic in it and had it look if the email contained the SMTPOriginator field. If it did, I then went through the logic of seeing if it was whitelisted in the user’s calendar profile and took action on it bases on that. Here is the code after I made my changes to it.Sub Initialize
Dim Session As NotesSession
Dim DB As NotesDatabase
Dim doc As notesdocument
Dim docProfile As NotesDocument
Dim strAction As String
Dim strFolder As String
Set Session = New NotesSession
Set doc = Session.DocumentContext
If doc.HasItem("SMTPOriginator") Then
REM Current Mail is marked as Spam
	Set DB = Session.CurrentDatabase
REM Get Mail Preferences with Spam Settings
	Set docProfile = db.GetProfileDocument("CalendarProfile")
	If Not docProfile Is Nothing Then
REM Check whether sender is listed in personal Whitelist
		If Not IsInWhiteList(db, doc, docProfile) Then
REM Get selected Action
			strAction = ""
			If docProfile.HasItem("SpamOptionsTX") Then
				strAction = docProfile.SpamOptionsTX(0)
			Select Case strAction
			Case "M" 'Move to a folder
				strFolder = "Spam"
REM Get Folder name
				If docProfile.HasItem("SpamFolderTX") Then
					strFolder = docProfile.SpamFolderTX(0)
					If strFolder = "" Then
						strFolder = "Spam"
REM Move document to folder
				Call doc.PutInFolder(strFolder,True)
				Call doc.RemoveFromFolder( "($Inbox)" )
			Case "D" 'Delete document immediately
				Call doc.Remove(True)
			End Select
and the Function…
Function IsInWhiteList(DB As NotesDatabase, Doc As NotesDocument, docProfile As NotesDocument) As Integer
IsInWhiteList = False
Dim docWhiteList As NotesDocument
Dim strFrom As String
Dim strTemp As String
	strFrom = Ucase(doc.SMTPOriginator(0))
Else
REM This is not an SMTP Message
	Exit Function
If strFrom = "" Then
	If doc.HasItem("From") Then
		strFrom = Ucase(doc.From(0))
	Else
REM Unable to determine the sender
		Exit Function
Forall strAllowed In docProfile.SpamWhiteListTX
	If strAllowed <> "" Then
REM WhiteList may contain complete mail addresses like ‘John@domain.com’ …
		If Instr(strAllowed, "@") > 0 Then
			If Ucase(strAllowed) = strFrom Then
				IsInWhiteList = True
				Exit Forall
		Else
REM … or just domain names like ‘domain.com
			strTemp = Mid$(strFrom, Instr(strFrom, "@")+1)
			If Ucase(strTemp) = Ucase(strAllowed) Then
				Exit Forall
End Forall
End Function
This worked great! Once a user feels that everyone is in their whitelist, they can just change the option in the profile to Delete instead of Move.
Here is where I need help on…
Upper Management wants to be able to check a master whitelist first before checking the user’s whitelist. This led me to this thread->
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/ceaccb7e8ce30b6985256d0200492b47?OpenDocument
What I would like to happen is for the email to come in, and the Process Spam agent kicks off before new mail arrives. It first checks the profile document in the master whitelist and if found, sends the email to the user’s Inbox. If the email sender/domain is not found, it then checks the user’s CalendarProfile and if in the user’s whitelist, send to Inbox, if not, send to the JunkMail folder, or whatever option they have selected.
Sorry for the long post, I just felt that I had to be very detailed in what I was needing help with. Once I get this working, I will either post it in this thread or create a database and submit it to the sandbox, as this seems to be something that a lot of people could use.
TIA,
Clint
