Hi All,This code is creating and updating records in lotus db taking data from Oracle.
When the record is created / updated for one employee number at the same time I need to update a flag value in Oracle as 'Y" that this record is updated.
Can you please confirm if I have used the correct syntax.
Thanks in advance .
Code---------
Dim db As NotesDatabase
Dim doc,newdoc As NotesDocument
Dim ldoc As NotesDocument
Dim LogDate As Variant
Dim view As NotesView
Dim upd , newd As Long
Dim upd1 As Long
Dim LC_S As New LCSession
Dim LC_FldLst As New LCFieldList(1)
Dim fields As New LCFieldList(1)
Dim LC_Conn As New LCConnection ("oracle")
Dim count As Long
Dim SelectStatement As String
Set session=New NotesSession
Set view = db.GetView( "NRIDview_HRMS" )
'To update flag value in ORacle // Please check this part
Set fields = New LCFieldList
Set field1 = fields.Append("HRMSFLAG", LCTYPE_TEXT)
upd=0
upd1=0
newd=0
LC_S.ConnectionPooling = True
LC_S.ClearStatus
LC_Conn.Metadata = "XX_ORACLE_TO_TBL"
LC_Conn.Server = "TEST"
LC_Conn.UserId = "apps"
LC_Conn.Password = "apps"
LC_Conn.CommitFrequency = 0
LC_Conn.Disconnect
LC_Conn.Connect
Print "Successfully connected to Server."
'Excecute selection
If (LC_Conn.Execute (|SELECT * FROM XX_ORACLE_TO_TBL|, LC_FldLst) = 0) Then
Print "No record matching query."
Else
count=LC_Conn.Fetch(LC_FldLst,1,1)
While (count >0) 'And LC_S.Status=LC_Success
Set doc = view.GetDocumentByKey(LC_FldLst.EMPLOYEE_NUMBER(0))
If Not doc Is Nothing Then
'Chek to be applied based on last modify incase of mismatch only update old records
doc.Name=CStr(LC_FldLst.Name(0))
doc.STAFF_ID=CStr(LC_FldLst.UNIQUE_ID(0))
doc.GENDER=CStr(LC_FldLst.GENDER(0))
updatedlog= updatedlog & Chr(10)& "Record updated for - " & LC_FldLst.EMPLOYEE_NUMBER(0) & " > Staff Name - '" & doc.Name(0)
Call doc.save (True , False)
upd=upd+1
''''A flag will be set in Oracle for this row '''''// Please check this part
field1.value = "Y"
Else
Set newdoc = db.CreateDocument
newdoc.Form = "ResourceNew"
newdoc.ALT_STAFF_ID=CStr(LC_FldLst.EMPLOYEE_NUMBER(0))
newdoc.Name=CStr(LC_FldLst.Name(0))
newdoc.STAFF_ID=CStr(LC_FldLst.UNIQUE_ID(0))
newdoc.GENDER=CStr(LC_FldLst.GENDER(0))
Call newdoc.save(True, False)
Createlog= Createlog & Chr(10)& "Record created for - " & LC_FldLst.EMPLOYEE_NUMBER(0) & " > Staff Name - '" & newdoc.Name(0)
newd=newd+1
field1.value = "Y"
LC_Conn.Update(fields) // Please check this part
Wend
