what is the maximum size for a script library using lotus script?
Subject: RE: what is the maximum size for a script library using lotus script?
Please, could you elaborate on the question?
Subject: what is the maximum size for a script library using lotus script? - from the help file
Limits on compiler and compiled program structure in LotusScript
Item Maximum
Number of lines per script or source file, not including the contents of %Include files 64K
Depth of nested %Include directives 16
Number of compilation errors before the LotusScript compiler halts 20
Number of symbols in a module’s symbol table. 64K
Number of recursive calls (recursion level for a given function) 32Kbyte stack size
Storage size of all data in a given scope (See “Storage size of data,” below.) Module: Limited by available memory.
Class: 64K bytes
Procedure: 32K bytes
Size of executable module code Limited by available memory.
The limits on the storage size of data in a given scope apply to fixed-size variables: scalar variables except for variable-length strings; user-defined type variables; and fixed arrays of these scalar variables and user-defined type variables. Depending on the order of declaration, alignment of variables on storage boundaries can take extra space. For example, an Integer variable is aligned on a 2-byte boundary, and a Long variable is aligned on a 4-byte boundary.
The maximum size of data in each dynamic variable (each variable-length string, each list, each dynamic array, and each instance of a class) is limited by available memory. However, each such variable will use 4 bytes for data in the scope where it is declared.
Because of run-time needs, LotusScript might generate an Out of stack error just before it reaches the data storage size limit.
JYR
