What is possible with "Read public documents"?
In the last few hours have turned a bit confused about ACLs in databases…
When a DB is created it contains a Default and Anonymous but with the type Unspecified and with No Access.
At the same are the last 3 settings in the ACL enabled, Write public documents, Read public document, replicate and copy documents.
I am not sure who can read and write public documents when both are set to No Access. Why is it like this? And why cant I disable the read and write public without the “replicate and copy” by disabled and grayed out??? I think that is quite strange!!
I am afraid that even they have been set to No Access can some (no idea who) still read documents in the database…
Or does it make sense when I say that the read/write public documents are used if a form contains a field for read/write access?? And only in that case can people read/write documents to the database (and if not included there is no kind of access to the db)???
Can somebody please explain this to me - right now I dont get it…
Sorry!
//Kjeld
Subject: What is possible with “Read public documents”?
The Public Documents settings will override the No Access setting. Usually, on a mail file, this allows anyone to look at your calendar entries without having to be set up in the ACL.
Because if you have no access to normal documents, and cannot read public documents, there’s nothing in the database you are allowed to see, so what would you be replicating or copying ?
