Weird problem with Items on form
Hi
I am trying to compare fieldvalues from 2 databases.
I am using this code just to access the to views and the documents.
Dim session2 As New NotesSession
Dim db As NotesDatabase
Dim db2 As NotesDatabase
Dim Movexview As NotesView
Dim Notesview As NotesView
Dim MovexDoc As NotesDocument
Dim notesDoc As NotesDocument
Dim idag As String
Set db = session.GetDatabase("DKDANNOT1/SpiraDK", "Databaser\IT\ProdSpecPump.nsf")
Set db2 = session2.GetDatabase("DKDANNOT1/SpiraDK", "Databaser\IT\SpecDB.nsf")
Set Movexview = db.GetView ( "Movex" )
Set Notesview = db2.GetView ( "LEI" )
Set MovexDoc = Movexview.GetFirstDocument
Set NotesDoc = Notesview.GetFirstDocument
the weird thing is that I dont get all the Notesitems on the forms, when I run the code with the debugger I get aprox half of the fields, somehow the other fields dos not exist for the debugger. ( I look under the section Items in the debugger, there I can see most of the fields)
I am using subforms but the values I want to compare are in the original form.
I can see the fields in the view, can add them to a column.
do any of you have had this problem, and how did you fix it ?
