Weird FT search problem
Hi All,
I have a weird FT search problem. I have a database with 2 documents looking like this:
document 1:
value of field RB_MemberID = “documentID1”
value of field Art_txtTitel = “goede zalf”
document 2:
value of field RB_MemberID = “documentID2”
value of field Art_txtTitel = “heel goede zalf”
When I type this search string into a notes client FT search I only get one result:
(FIELD RB_MemberID = “documentID1” OR FIELD RB_MemberID=“documentID2”) AND FIELD Art_txtTitel contains alf
I’ll get the document with documentID2… HOWEVER if I screw up the documentID2 in the search query and make it:
(FIELD RB_MemberID = “documentID1” OR FIELD RB_MemberID=“documentBLAHBLAHID2”) AND FIELD Art_txtTitel contains alf
I’ll get the first document!
The same thing happens in LotusScript when I do a NotesView.FTSearch with the same searchstring.
Thanks for any pointers / help.
Kees.
Subject: Weird FT search problem
I have experienced such problem a lot of times. The new FT search engine has serious problems with using
wildcards within the query.
Look at this (the quotations are from Domino 6.5.3 Release Notes):
#1 (chapter “Search Query Troubleshooting and Limitations” ) –
"You may experience problems searching in the Names and Address Book database.
Performing a “fielded” search, using the wildcard option with the singular
letters A through F, may not return all valid search results.
This is a Search Engine software limitation."
#2 (SPR DMAS4M7JUK) -
"Search results are not cleared if a document from a Database is
left open while the database is closed and re-opened.
Occurs when sort option is set to “Keep Current Order” or
"Show all documents.
This issue applies to full-text searching of Server databases only."
Even #1 says the problem is only with Names and
Addres Book it happens widely with ordinary databases and
it usually does not depend on a way you combine a wildcard
with you query, singular or multiplier letters etc.
Pay your attention that it is a “limitation” and therefore the chances
that it will be fixed are very small.
This is on the same topic:
http://www-1.ibm.com/support/docview.wss?rs=463&context=SSKTMJ&context=SSKTWP&dc=DA490&dc=DB520&dc=DA4A30&dc=DB530&dc=DA480&dc=D700&dc=DB500&dc=D400&dc=D600&dc=DA400&dc=D420&dc=DA4A10&dc=D410&dc=DA4A20&dc=DA460&dc=DA440&dc=DA430&dc=DA470&dc=DB550&dc=D430&dc=DA420&dc=DA500&dc=DA410&dc=DB540&dc=DB510&q1=wildcard&uid=swg21092746&loc=en_US&cs=utf-8&lang=en
If you find solution for the issue (I hardly believe you do) please post it here.
