Weekly Syndicator Rebuild required?
We restart our Subscriber portals every eary Sunday morning. (not at the same time).
Auto Syndication stops until the Syndicator is manually done with the 'rebuild' option. It then works fine for the rest of the week.
Any ideas?
A rebuild or manual syndication update should not be a requirement.
Once the subscriber servers are restarted, do you see the syndicator status shows pending, and the subscriber status shows idle?
In order for automatic syndication to function properly, the wps/scheduler needs to be running on the syndicator node that is performing syndication.
When the subscriber servers are restarted, does the syndication server make any references in the logs to wps/scheduler losing its lease?
RE Synd/Sub Status: The restart occurs at 4a. No one is around to watch it. Is there something in the log to check?
RE Scheduler: The wps/schedule doesn't complain about losing its lease when the subscribers are restarted.
Note: The Syndicators are restarted on Tuesdays. Syndication is affected when they restart.
As the logs does not mentioned the lease being lost for wps/scheduler, I would suggest enabling syndication tracing on synd and sub, restarting the server and reproducing the behavior, open a case with the HCL support team for detailed review.
