WEBQuerySave not running on some documents
I am seeing a strange error on the WebQuerySave event for some documents.
It reports Server is not a known tcp/ip host
Has anyone seen this error?
The website is running fine, as I say some documents run it perfectly but some just dont.
Are you sure it is not a error in your WebQuerySave code ?
Can you share the code ?
There is no reference to any website or url in the agent Surely if there was then it would not have run for all these years and continue to the majority of the time But thanks anyway
This could also be a function to open a database which has a server not reachable.
Maybe user specific so it happens not every time
I hear you but no, its just using documentcontext.
Has to be something with the document as fails for multiple users on multiple browsers but other documents are fine.
Hi Gary
The code in webquerysave event might help in analyzing further. Also check whether there are any errors
at server console during the time of the issue.
Also the possible reason for this is the document fields are trying to recalculate the values and could not find
the server. Check for the document properties and compare between working and non-working documents.
The above would help in further narrow down the issue.
