I’ve got a very straight-forward yet puzzling problem. In my web app, the webqueryopen script is not running on two of my servers. The code is the same on all of them. I put a messagebox on the first line of the agent yet I see nothing written to the log and it is obvious on the screen that it did not run. Any ideas?
Subject: WebqueryOpen not running
All WebQueryOpen output is stopped and wont’ be seen. Create a new field that is written to by the agent then look at that field.
I use this method for displaying web error messages. I trap the runtime error with an On Error. The “errorfield” is then hidden unless it isn’t blank.
Hope that helps.
Subject: RE: WebqueryOpen not running
Since when? I print to the log just fine on my 6.53 box
Subject: Maybe I’m confused. Perhaps its just standard out that is stopped?
Yep… I stand corrected…
Help says:
WebQueryOpen events
A WebQueryOpen event runs the agent before Domino converts a document to HTML and sends it to the browser. Domino ignores any output produced by the agent in this context.
Chuck
Subject: RE: Maybe I’m confused. Perhaps its just standard out that is stopped?
I use text output to a NotesAgentLog
Then in designer I open the agents section and go to Agent > Log and the log is populated with my outputs.
Web Agents won’t run Print commands because the Print method sends output to the browser. While posting a form to the browser this output is ignored.
I’ve been looking at using the Remote Debugger to get a hook into my web agents, but we don’t have a dev server so I haven’t tried it yet. Supposedly you can add a Stop instruction to the agent, and it’ll wait until you connect to the server’s remote debugger to get a debugging console started … you can then skip through the agent like the normal Notes client debugger … wouldn’t that be cool ![]()
