Web view opens associated doc on double click, How to override?
I have a search result in a view on the Webb. My wish is when you double click on appropriate row and column in the view, it will open a new page that takes the value from the view column as input parameter. Instead of the default action when it opens the associated document.
I am trying with javascripts and maybe an agent.
Is it possible to do this right and easy?
Many thanks!
Jonas :wink:
