Web Search Problem
I have create a DB.Some Document are Public Access and some are not on the web.
In the ACL, I set the Anonymous user as No Access but the public document.
It works fine.
However, I found that a Anonymous user can not use the search form after clicking the search button. Login is required for the searching.
If reader is assigned, it work ok but the anonymous users can read all documents.
So. how can I setup to let web user to read public documents, all notes users can read all documents through web and notes interface.
Subject: Web Search Problem
you can work with reader fields, create a role which every notes user has and put it in a reader field in the documents except public documents.
Did you enable the option public access to the search form? I thought this would be enough tp
give the public users the right to search
