Web page refresh problem
How can I refresh the content of an iFrame in web??
Thanks in advance…
Subject: web page refresh problem
HiIt depends on from where you would like to refresh the frame. If you would like to refresh the frame from the same iframe I would create a button and have the web onclick event set to
window.location.reload( false );
If you would like to refresh a frame from the parent frame use the following
document.getElementById(‘idOfFrame’).contentWindow.location.reload(true);
This will work both in FF and IE.
I hope this solves your problems
Best regards
Olle
