Web form save problem
Hi,I have created a web form for Anonymous - Depositor access.
After pressed on the submit button, the document is stored in the data base. However sometimes the Login window appears in place of the content of the $$Return field.
Any idea?
Christina
Subject: web form save problem
When Web users submit a document, Domino sends them the default confirmation message “Form processed.” To change the default message, add a computed text field to the form, name it $$Return, and use HTML as the computed to link to another page
Subject: RE: web form save problem
Thanks for the response.
Yes I know. That is that what I have done.
My problmem is, that sometimes the login window appears instead of the content of the $$return field. But only sometimes… The other times it works fine…
The page you are redirecting ton using the $$Return field, is also accessible for anymous users?
In my $$Return field I have only some HTML-code.
The access rights of my web form are:
Default: No Access
Anonymous: Depositor
OK, I think I found the problem but I don’t now to solve…I created a database based on the addressbook template. This db is used for registration of external persons by the internet. In my web form I have the field InternetAddress.
Always when I enter a valid email address (including the @) I get the Login window.
When I put only some text in this field (without @) it works fine and I get the $$Return window.
Any idea why?
Christina
