hcl-bot
1
I have a form with a submit button. The button checks for field validations (using JS ) and I have a $$Return field with this value…
workView := @ReplaceSubstring( viewID; " "; “%20”);
_tDb := @ReplaceSubstring(@Subset(@DbName; -1); " “:”\" ; “+”:“/”);
“[http://mail2.DOMAIN.com/”+ _tDb +“/”+ workView+“?OpenView&DblClkTarget=_self]”
When the submit button is pressed, domino is supposed to look for this field and process it…
If I copy and paste the runtime value of $$Return in a browser… it does open up correctly…
for the life of me I cannot figure out why the error occurs…
Anyone have any ideas?
Thanks,
Brett
hcl-bot
2
Subject: Web Exception - Entry not found in index
workView depends on viewID. Is viewID set?
Instead of
have you tried
_tDb := @WebDbName;
If this is not the problem, you need to supply more information about your code, and what happens, and what should happen.
/Peter
hcl-bot
3
Subject: RE: Web Exception - Entry not found in index
Hi Peter… Thanks for your response.In the submit button there is this javascript… (which should be fine)…
/* Function to validate fields in a submit button on a form*/
function CheckField()
var message = “”;
if( TDIManRep.value=="")
{ message = message + "Salesperson field. \n"; }
if(Territory.value=="")
{ message = message + "Salesperson's Territory. \n"; }
if (cus_Target=="")
{ message = message + "Customer Target. \n;"; }
if(Company.value=="")
{ message = message + "Company Name. \n"; }
if(EquipmentType.value=="")
{ message = message + "Equipment Type. \n"; }
if(RespondBy.value=="")
{ message = message + "Respond By Date. \n"; }
if ( Year1.value == "")
{ message = message + "Projected this calendar year $$ values. \n"; }
if ( Year2.value == "")
{ message = message + "Projected next calendar year $$ values. \n"; }
if(message.length > 0)
{ alert( message + "\n Please fill in the required areas listed\nabove before submitting document\n\nThank you" );
return false; }
else
{ submit (); }
and in the $$Return Field I have: (now)
_tDb := @WebDbName;
“[/”+ _tDB + “/”+ workView+“?OpenView&DblClkTarget=_self]”
ViewID is a computed field which holds the “opening View” so you can go back to where you came from before you opened the document.
The URL int he $$Return field looks correct and I can use that url in a copy and paste into a seperate browser and open the view…
The $$Return value is:
Return Field : [/sales/salesopp.nsf/All%20Sales%20People?OpenView&DblClkTarget=_self]
hcl-bot
4
Found the problem…
I had webquerysave agents being called in the webquerysave event that didn’t exist any more…
Just another DOH! moment.
thanks to all.
