Hi Friends,
I need a suggestion about how i can use WebCam or How i can take picture using Webcam using Lotuscript Code
it should work on Web
Give me any guidlines u have i have just started R&D from today
Desperately waiting for Replies.
thnks in Advance
Sunit
Subject: Web Cam using LotusScript(Web Application)
Hi
I previously posted response to the same question.
If you want to take picture from web cam (web). then you have to develop web cam viewer then embedded into domino webform. This viewer can be designed by using active-x ctrl or java applet or installing some streaming softwares or you can get from third party (search in Google.com).
This viewer will come with all controls. If ur very good in java or vb6.0 or .net. develop ur own viewer with your trademark.
good luckā¦
dominodesigner@ymail.com
