Subject: Web Authentication Problems
The cause of the problem cannot be resolved. The current state of play is that:
There are two databases, TS2.nsf and GeneralComms.nsf. GeneralComms contains a URL to TS2.nsf. All users are web users. Both are on 1 server, EASTINT. The normal procedure is that the user authenticates against GeneralComms.nsf and this authentication is used also within TS2.nsf. The first time the user The ACL levels of both databases have been checked. There appear to be no relevant entries in log.nsf or domlog.nsf.
We see the re-authentication problem if:
{A1} We access TS2.nsf through GeneralComms inside the store network.
{A2} We access TS2.nsf through a copy of GeneralComms (made by copying GeneralComms to another temporary database, then copying back to GeneralComms.nsf, overwriting the original)
We do not see the re-authentication problem if:
{B1} We access TS2.nsf directly inside the store comms network (i.e. without using the URL in GeneralComms.nsf).
{B2} We access TS2.nsf through GeneralComms.nsf or directly but outside the store comms network.
{B3} We copy GeneralComms.nsf to another database name in the same location (e.g. GeneralComms2.nsf) and access TS2.nsf through the normal URL link inside the store comms network.
If this was an ACL problem, then we should not observe the difference in behaviour in {A1} and {B2} - the databases remain the same and the server is the same.
If this was an application problem, then we should observe no difference between {A1} and {B3} - the applications remain the same.
If this was a network problem, then we would probably not see the difference between {A1} and {B3}
Curiouser and curiouser . . . if anyone can shed any light on this, I’d be grateful!
