Web Attach Problems
Please help me,
I have a application web, and I need to attach several files in different rich text fields, at the same time.
As I must do it?
Thanks.
Subject: Web Attach Problems
You can add Web File Upload controls to your form and use a QuerySaveEvent agent to put the attachments into the required field(s).
Alex
Subject: RE: Web Attach Problems
Alex’s answer is correct and is the easiest way to do it, but you may come across a problem adding many files at once, as the standard file upload control is one file at a time. If you want to upload 10 files you need to add 10 file upload controls.
If you are looking for something a little more interesting you could try using the Inotes Activex FileUpload Control. It is more work but may suit your needs.
http://thehojusaram.blogspot.com/2006/09/domino-activex-inotes-file-upload.html
Thank you Alex and Simon, Your help has been very important and very useful.
Greetings
Alejandro.
Thanks again Simon and Alex,
My problem I am solved partly, now I was with a new problem, if I have two fields “Rich Text”, “A” and “B”, also I have two “File Upload Control”, How I make to put the file of the first “File Upload Control” in the field “A” and to put the file of the second “File Upload Control” in field “B”, has like doing that?
Thanks Experts
