Web application issue
I have just created a web form on a web application that sends a link to the approver via email with a link of the doc. The problem I have is that when the approver clicks on the link it does not open the document but opens the default framesets. What do I need to do to the application inorder for the link to open the document directly?
Below is the link that the user recives that opens the default(appframe) framesets.
http://intranet.xxxxxx.com/apps/xxxxxx.nsf/appframe?open&PI.6UQLK6
Subject: Web application issue
Construct the url like below:http://intranet.xxxxxx.com/apps/xxxxxx.nsf/0/DocumentUNID?openDocument
HTH
Adi
In my web apps that are framed, I usually have a page open and it checks for a parameter in the URL such as id=xxx. If it sees that parameter, then it opens that document within the context of the appropriate frameset. If not, it opens the default stuff.
regards,
raphael
You need to generate this link using the domino URL command Open Document which uses the document Unique ID or a unique key in a view (first sorted column), there are several options on how to do this:
1.Opening from a view using a unique key in the first sorted column of the view:
http://intranet.xxxxx.com/apps/xxxx.nsf/[ViewNameorAlias]/[UniqueKey]?OpenDocument
2.Opening form a view using the document Notes UID
http://intranet.xxxxx.com/apps/xxxx.nsf/[ViewNameorAlias]/[NotesUID]?OpenDocument
3.Opening directly using the document Notes UID
http://intranet.xxxxx.com/apps/xxxx.nsf/0/[DocUID]?OpenDocument
If you are generating the email or link using formula language, you can use the @DocumentUniqueID function to get the Notes ID:
Formula language for example 3
MyURL := “http://intranet.xxxxx.com/apps/xxxx.nsf/0/” + @Text(@DocumentUniqueID) + “?OpenDocument”
Subject: RE: Web application issue
Thanks, I used formula language and it works. The only question stil lingering in my mind is that the format I used before works on all our other applications. I dont know why it does not work on this new application
if it works for one - it will work another
something is different - find that something, and you have your answer -
