I have a web application. I changed the ACL level for a group from Author to Reader and the users could not access the application.
I changed the group’s ACL back to Author, and added Create Documents back (changing to Reader automatically removed that), but the users in that group still can’t get access.
What else could be wrong? I’m in dire straits here, so any help is appreciated.
Thanks. I don’t have access to the server, but it seems to have fixed itself after a few minutes, so I guess the server’s cache just had to catch up.
May I ask another question: I want to change these web users from Author access to Reader access, but that breaks the application entirely. What might cause that problem? Shouldn’t they be able to get in, but only read documents, just not edit them?
There are several possibilities. Likely there is a field or form event which tries to create or modify a document or profile document. How does it “break the application entirely”? Are there errors in the server log.nsf? What errors does the user see?
