Web Access (iNotes) problem
The return address from DWA shows up like this
Steve_Johnson/XYZ%XYZ@domain.com
when sent to internet address… is ok Notes to a Notes address in same domain.
The location doc is set correctly and the return address is fine from Notes client on Windows…
Tried lot of stuff nothing seemed to work.
Subject: Web Access (iNotes) problem
Check that you have specified the domain correctly. I had a similar problem with the email address for a group picking up an additional %DOMAIN.
hunty
check this:
https://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/179a44ad414f87718525714f0047c948?OpenDocument
