I just upgrade a domino 8.5.1 32 bit server to 9.0.1 64 bit server on windows 2008.
I have an application with a very large view that seems to build, but will not display quickly. It takes 5-10 minutes everytime it is opened. It works fine on 8.5.1 on another server. I’ve tried a new replica, fixup, and copy style compact. I even rebuilt the view design from scratch. Nothing works. Any ideas?
Subject: View Rebuild
I am not seeing those error message and I am able to see the optimized rebuild files when the view is first built. The view actually finishes building, yet the speed issue persists.
Subject: Disk IO
This system is actually on a Fusion IO, and the statistics indicate the issue is not with disk IO.
Subject: Anti Virus
Can you confirm that if there is any Anti Virus software on the server that it is excluding the Notes directories, temp directories or other directories specified in the notes.ini for rebuilding the views
Subject: These errors are showing on the console occasionally.
Subject: could you do a few nsd -stacks while it is being opened
you can zip/tar them up & send them to me
swatts@notesdev.ibm.com
–Steve
Subject: No Anti Virus Software
There is no anti virus software on the server.
Subject: i/o
i know LkMgr error messages with slow SAN oder Harddisks. Maybe a problem with disk i/o!
Regards
Christoph
