I´m using “@command([ViewCollapseAll])” in the view´s postopen event but always when I use the view show me “cannot execute the specified command”. I need this view collapsed every time I use. What can I do? What´s the problem? It´s work fine for everybody that try to help me, except for me.Thanks
Subject: view - URGENT - help me
Did you try to set “Collapse all…” view property instead?
Subject: RE: view - URGENT - help me
Yes, I did, but it´s work only in the first use! I need every time!
Well, it works every time for me.Is this for Notes or for the web?
Try saving the view from Designer with all collapsed.
Simeon
For Notes.
I tried but not different happened
Subject: Do you have “Allow Customizations” enabled?
Just a thought, I have no clue if it will have an affect… If its enable, try disabling it. You can find it in the 2nd tab of the View properties dialog.
