I’m having problems with the SELECT statement used to select documents within the View Selection.
The follow code does not work(1st attempt):
one = “Open”
two = “Closed”
formula = |SELECT IssueStatus = [| & one & |] & IssueStatus = [| & two & |]|
I’ve also tried the following
The follow code does not work(2nd attempt):
formula = |SELECT IssueStatus = “Open” & IssueStatus = “Closed”|
Error from above code:
Notes error: Unknown [KeyWord] for @Function (SELECT IssueStatus = [Open]&IssuesStatus = [Closed]
What I am trying to do is to select all documents that have either ‘Open’ or ‘Closed’ status. Can anybody help please?
Thanks in advance!
