Hi
Can anybody please help me in my issue? I have a webform which has 2 fields Name & Age. There is an edit button thru which user can edit the document and update the values in the fields. There is a save button which runs the agent. Agent will update the value and save the particular document. This agent i called thru ajax code. After running ajax code and calling the agent i called a page which has a @dblookup formula on the computed value to fetch the updated values of Name, Age and print them on the page. But it is printing previous values.
I think it is not a web browser cache problem. View is not refreshing up when @dblookup fetch data. I used “” in the @dblookup formula in place of “NoCache”.
Please help.
Subject: View refresh problem in web
HiNow I might be a complete idiot here, but why do you need to reload the page if you just saved the content?? It’ll only reload the thing that you saved… But I tried it and it worked like a charm when I loaded a page with the data in it(but then I used the prototype framework)
Subject: RE: View refresh problem in web
Actually i do not want to reload the whole page I only need that the data updated will also update on the form.
Actually I have put a html view on the form at
element. So when I update the values in the document, I also need to update the html based view on the form so that updated values will be displayed on the form in the html view.
View does not get refreshed at my end. Can u send me the sample database where this thing is working. My email id is kgaurav1978@yahoo.com
