An application module was working fine. It used to update dates from one document ( say doc 1 ) to another document ( say doc 2 ).
What the code does is, once the “doc 1” is saved, it get handle of the view in which “doc 1” updates. From that view, it gets the “doc 1’s” new updated dates and does some compuation with it and saves the “doc 2”.
What is it that I’m facing here is, I’m not able to retreive the latest dates saved in “doc 1” from the view. I have tried - AutoUpdate, Refresh. Doesn’t work. FYI, this entire module is in an external script library function. So, we are here doing a call to that function.
When we use/ copy that external function in the same agent internally, it works fine. Can you pls help in communicating the issue cause, if by any chance, had you ever gone through this.
For simple operations on a document that affects its continued presence in the view that you are looping through, you must set the next document before doing that action.
The code would then look like this:
While Not (doc Is Nothing)
… Set nextDoc = view.GetNextDocument(doc)
… ’ – do your actions
… Set doc = nextDoc
Wend
If your actions affect not only the current document but also other documents in the view, it is better not to work with the view at all but with a collection of documents, which can be accessed in two ways:
… using db.Search() → a document collection
… using view.AllEntries → a collection of view entries, each containing a document.
