hi ,we are using short cut shift±- for minimizing the documents in pick list .
But we are facing problem that some time view becomes blank …means user is not able to see aby document in this view after pressing shift±-
Any luck.
Any luck.
Subject: View problem
Check scroll bar. If the categorized views are closed then some times u would need to scroll up to see the closed categories.
Subject: RE: View problem
Thanks .But when we are doing Shift+ – then scroll bar is disappearing .
any Idea.
