hcl-bot
1
Actually I have a filed which contain multi values and my requirement Is, I have to show this value in view in one by one
e.g.----- if field contain value:- Try, same, make
and view it should come in format like:-
Try
Same
Make
Its argent please help me
hcl-bot
2
Subject: view Problem
Use multi-value separator option of view’s column property. That will show values in diff. rows.
hcl-bot
3
Subject: RE: view Problem
Hi Amit…its easy …just go to that column properties and select "new line "option in multivalue field…hope u will get ur answerbye
