View icon help
Hi, probably a very easy thing to but I want a icon to show in the inbox view when the $dnsblsite contains an entry so I know its spam.
I think I know the formula but not sure how to add it into the current formula which is
REM {This icon formula is used in ($Inbox) folder, (MailThreads) view, and ($All) view};
CSisPrivate := @If(@IsUnavailable($PublicAccess) & @IsAvailable($CSVersion);“1”;“0”);
isImportant := @If(Importance=“1”;“1”;“0”);
ViewIcon2 := @If(_ViewIcon = 158 & AppointmentType != “1” & BookFreeTime = “1”; 12; _ViewIcon);
tmpIcon := @If(ExpireDate !=“” ;64;displaycopyto_icon = “1”;“sentto.gif”;
@If(DeliveredDate = “”;
@If(PostedDate="" | @IsUnavailable(PostedDate);
    @If(@IsAvailable(IsMailStationery);
        21;
@If($dnsblsite=“bl.spamcop.net”);
    115;
    @IsAvailable(_ViewIcon);
        ViewIcon2;
     58);
@If(IsImportant="1";
    124;
122));
ViewIcon2;
$TypeIcon));
REM; “If the Task has no icon, display the invitation icon - backward compatibility”;
varTaskIcon := @If(Form = “Task” & (!@IsAvailable(_ViewIcon) | ViewIcon2 = “”) & (!@IsAvailable(_ViewIcon2) | ViewIcon2 = “”); @False; @True);
iconOne := @If(!varTaskIcon; 133; @If(tmpIcon = “”; 0; tmpIcon));
iconTwo := @If(iconOne=124;0;CSisPrivate=“1”; 164; isImportant=“1”; 150; 0);
iconOne:iconTwo;
If anybody can help that would be great
thanks
Scott
Subject: View icon help
If you add @IsAvailable($DNSBLSite);87; to the end of the tmpIcon := line, you’ll get a little frowny face next to anything flagged with a $DNSBLSite item, regardless of the blacklist used. The full column formula I tested in the R6 mail template is below.
tmpIcon := @If(ExpireDate !=“” ;64;displaycopyto_icon = “1”;“sentto.gif”;@IsAvailable($DNSBLSite);87;
        21;
        ViewIcon2;
     58);
    124;
122));
ViewIcon2;
$TypeIcon));
iconOne:iconTwo
