View Help
Hi There,
Looking for some help with a view, I’m not sure if I can do it, but thought I would run it passed you all…
I have a form, on that form is an embedded view which only shows just a Single Category.
What I would like to do is build a view which shows the documents and the documents shown in the embedded view.
Is this possible? Apologies if I haven’t exmplained it well enough.
Thanks !
F1H
