View help
Hi to all of you,
I have a little problem!
I have some code that is placed on a button on a document, I have to change it so I can place it on a view and it will change all documents where the field modem_a is empty and it will insert the values from another document over the UNID!
I dont know how to go trough the view check the values and how to insert the matching value!
Here is the code that works on a document!
Thank you in advance
Sub Click(Source As Button)
Dim s As New NotesSession
Dim tempdoc As NotesDocument
Dim uidoc As NotesUIDocument
Dim mbr As Variant
Dim naziv As String
Dim paket As  String
Dim placanje As String
Dim modem As String
Dim view As NotesView
Set db = s.CurrentDatabase
'Set newdoc = uidoc.Document
mbr = uidoc.FieldGetText("jmbg")
naziv = uidoc.FieldGetText("organizacija")
Set View = db.GetView("UgovoriBroj")		' view iz kojeg se izvlače podaci
															' sortirano po UNID dokumenta
			' UNID tekućeg dokumenta
Set tempdoc = view.GetDocumentByKey(mbr,True)
' ako dokument ne postoji unutar   baze ne nastavlja se sa daljnjim slanjem obavijesti
If (tempdoc Is Nothing)  Then
	Msgbox "Ugovor nije pronadjen u bazi ", 0+16,"Greška"
	Exit Sub
brugovor = tempdoc.ugovor_broj(0)
paket = tempdoc.paket(0)
placanje = tempdoc.placanje(0)
modem = Cstr(tempdoc.modem(0))
Call uidoc.FieldSetText("ug_broj",  brugovor)
Call uidoc.FieldSetText("modem_1",Cstr(modem))
If uidoc.FieldGetText("VrstaDokumenta") = "Priključak na Internet" Then
	Call uidoc.FieldSetText("paket",  paket)
	Call uidoc.FieldSetText("placanje",  placanje)
Call uidoc.Refresh
Subject: View help
I won’t bother with any lengthy code here, just the broad outlines.
You should create an agent that runs ‘on selected documents’.
In the view, create a button with formula @Command([ToolsRunMacro]; “NameOfAgent”)
In the agent, you will need this to get the collection of selected documents in the view:
Dim db As NotesDatabase
Dim coll as NotesDocumentCollection
Dim doc As NotesDocument
Set coll = db.UnprocessedDocuments
You now start a loop through the collection:
Set doc = coll.GetFirstDocument
While Not (doc Is Nothing)
… This is where you process your document…
Set doc = coll.GetNextDocument(doc)
Wend
The actual processing is up to you, but shouldn’t pose much of a problem. You will need to check the values and change docs whan needed. Something like this:
If doc.OneValue(0) <> “” Then
Call doc.ReplaceItemValue(“xx”, “yy”)
Call doc.Save(False, False)
If you are going to update the values in the selected documents with values from another document, you will of course need to gran that other document. Preferably by using GetDocumentByKey from a view.
Hope this helps.
// Ken
