Hello
Please need help, the notes base was converted to version 9.01 can no longer open any vision when I try to open the designer receives the following Feedback there are more data available, but the front end to view opens normally, or can no longer do changes.
Thank you in advance for help.
Thank you
Marcelo Merotto
Subject: Build Automatically is enable
Good Morning
In my case the automatic build is enabled, I believe that should be confiicts with something else because the notes server is running fine.
Thank you for your help .
Subject: Hm, is it possible “Build Automatically” was disabled?
That’s been my biggest stumbling block: Designer detects something in the application and disables automatic builds. It’s under the “Project” menu in Designer.
Aside, I know I’d like some way to control this (maybe a Designer option to prompt me when opening a DB for the first time), but just disabling automatic rebuilds has cost me more hours debugging.
