Vault problem
I have all thevault setup done. And also, the sh idvult command shows everythingpresent.
But when one logs into the server, no id gets copied to the vault.
Any ideas?
BTW I opened the vault and nothing there
Subject: Can you check log.nsf under Security events and post here?
It should show ID vault creation, and results of uploading.
Also, please copy in the results from “sh id vaults”.
Subject: SEE ABOVE
error and vault cert are displayed
