when i run the code below it is working fine :
Sub UpdateColumnHeaders( nameOfView As String,Offset As Integer, startdate As Variant )
Dim db As NotesDatabase
Dim view As NotesView
Dim vc As NotesViewColumn
Dim dd As Variant
Dim count As Integer
Dim daycount As Integer
Dim VarColor As String
Dim dat As Variant
Set view = db.GetView(nameOfView)
count = View.ColumnCount 'Count number of columns in the whole view
daycount = (count-offset)/2 - 1 'Prepare the dayscounter (substract offset, then divided by 2 (due to extra color colums)).
Set vc=view.columns(3)
dd = Format$(startdate.lslocaltime,"Short Date") 'set dd to datecount,and force dd/mm/yyyy format
vc.HeaderFontPointSize = 10
vc.HeaderFontStyle = VC_FONT_BOLD
vc.HeaderAlignment = VC_ALIGN_CENTER
vc.HeaderFontColor = COLOR_BLACK
vc.IsResize = False
vc.Title = Format$(dd,"mmmm yyyy")
vc.Width = 12
Do Until count = offset 'Do until offset reached (see intialize)
Set vc = view.Columns(count-1) 'Sets the column to be re-designed
dd = Format$(startdate.lslocaltime + daycount,"Short Date") 'set dd to datecount,and force dd/mm/yyyy format
’ vc.FontFace = “Webdings” 'Set default font/header options etc.
vc.FontFace = "Arial" 'Set default font/header options etc.
vc.Alignment = VC_ALIGN_CENTER
vc.FontPointSize = 16
Select Case Weekday(dd) 'Select headerfontcolor by weekday
Case 1 : vc.HeaderFontColor = COLOR_RED
Case 7 : vc.HeaderFontColor = COLOR_DARK_YELLOW 'Set to Dark yellow on saturdays
Case Else :vc.HeaderFontColor = COLOR_BLACK 'use black on other days
End Select
Case 1 : vc.FontFace = "Webdings"
Case Else :vc.FontFace = "Arial"
End Select
vc.Title = Format$(dd,"dd") 'Rename the colum to 2-digit day number dd
vc.Width = 1 '(Re-)set width to re-align the view (just in case user messed it up)
dat = Format$(dd,"dd-mm-yyyy")
'Rewrite the date column formula to avoid use of @today (This avoids unneeded refresh of index)
vc.Formula={""}
vc.Formula = {tel:=@member("} & dat &{";@explode(absencedaystotal));@if(tel<>0;approved:=@subset(approvetotal;tel);"");@if(tel<>0;approved1:=@subset(approved;-1);"");@If(sickdays="} & dat &{";"Z"; @if(approved1="V";@char(157);@If(VroegDatum="} & dat &{";"V";@If(MiddagDatum="} & dat &{";"D";@If(LaatDatum="} & dat &{";"L";@If(standby="} & dat &{";@Char(212);""))))))}
Call view.Refresh
count =count -1 'Select the corresponding color column (next column)
vc.Title = "C" & Format$(dd,"dd") 'Rename the colums to C(olor)+daynum
'Rewrite the color column formula that goes with the previous date-colum.
Select Case Weekday(dd) 'Select background color by weekday
Case 1,7 : varColor = "242:242:242" 'Set to lightgrey on weekends
Case Else : varColor = "255:255:255" 'use white on other days
End Select
vc.Formula={""}
vc.Formula = {red:=255:0:0;green:=0:222:0;yellow:=0:96:0;pink:=225:27:213;white:=242:242:242;plain:=0:0:0;tel:=@member("} & dat & {";@explode(absencedaystotal));approved:=@subset(approvetotal;tel);approved1:=@subset(approved;-1);@if(sickdays="} & dat & {";red;@If(absencedaystotal="} & dat & {";@if(approved1="V" | approved1="?" ;red;@if(approved1="X";yellow;@if(standby="} & dat & {";white:pink;green)));@if(standby="} & dat & {";white:pink;green)))}
count =count -1 'Select the next column
daycount = daycount -1 'and set the next day until offset is reached
Loop
When i change the following line :
vc.Formula = {tel:=@member("} & dat &{";@explode(absencedaystotal));@if(tel<>0;approved:=@subset(approvetotal;tel);"");@if(tel<>0;approved1:=@subset(approved;-1);"");@If(sickdays="} & dat &{";"Z";@if(alphen="} & dat &{";"1";@if(approved1="V";@char(157);@If(VroegDatum="} & dat &{";"V";@If(MiddagDatum="} & dat &{";"D";@If(LaatDatum="} & dat &{";"L";@If(standby="} & dat &{";@Char(212);"")))))))}
The i get the error variant does not contain container.
The problem is that after a few loops the view.columns is empty.
In the first code the problem does not exist.
Does anyone what this can be?
