Variant does not contain a container
When going to archive the mails in user’s pc from Action- Archive-Archive selected documents, it is giving a message ‘Variant does not contain a container’. Pl help me. This happend in my boss’s pc.
Subject: Variant does not contain a container
it´s a weird error. I remcommend you to replace the template, may be this can help you.Before replacing the template, please check which is the one the DB has (database - properties-design tab), to prevent changing it for another that is not the actual.
Good Luck!
Subject: RE: Variant does not contain a container
I have done following procedures individually, but no solved.
  1. fix up the database.
2)Refresh design.
3)Replace design.
