Variant does not contain a container
I have a form that goes through an approval process, and lately some of my users have been getting a popup stating “Variant Does Not Contain a Container” when approving. Using the debugger I was able to determine that it was occurring here: Forall c In Conditions
	Result = Evaluate(c, doc_)
	If Result(0) = False Then
		AllConditionsAreTrue = False
		Exit Forall
	Else
		AllConditionsAreTrue = True
	End Forall
Specifically at “If Result(0) = False Then”
I’m at a loss on how to fix this. Help?
Subject: variant does not contain a container
we need to know what you have inside “Conditions”.Could you post previous part of your code ?
Subject: RE: variant does not contain a container
Private Sub satisfyConditions Dim AllConditionsAreTrue As Boolean
	Dim Conditions As Variant
	Dim Result As Variant
	Do
		Set workflow_ = workflow_.GetNextStatus
		If workflow_.HasConditions Then
			Conditions = workflow_.GetConditions
					Exit Forall
				Else
			End Forall
			If AllConditionsAreTrue = True Then Exit Do
		Else
			Exit Do
		Call Me.signAndDate
	Loop Until workflow_.HasNextStatus = False
