Varaint does not contain a container?
The code is to access the value of rich text, it shows “Varaint does not contain a container” in line item.Values(0), but item.Values has value when I use debugger to view it. The code works fine for other richh text field. I has compared the rich text properties of “RTItem” and other rich text. It is the same. What is the problem came from?
rich text properties:
Rich text Lite
  • Photos
  • Graphics
  • Attachments
  • Text
The code as below:
Dim item As Variant
Set item = curdoc.GetFirstItem(“RTItem”)
If item.Values(0) <> “” Then
End if
Subject: Varaint does not contain a container?
Based on Domino Designer help, the Values property for a Rich Text Item:“String. The text in the field, rendered into plain text.”
I am guessing that since a string is returned, I think the item.Values is considered a string and you should be able to check it that way ---- no (0) at the end…
Or try cycling through it:
Dim thisValue as string
Forall values in item.Values
thisValue = values
if len(thisValue) <> 0 then
'your code…
end if
End Forall
HTH, Dan
