In My application form i have text feild where the multiple number are entered.I need the validation in such a way that only single use of each number allowed in the text feild using Louts script
Please help me to solve the issue
Regards
Sruthi
Regards
Sruthi
Subject: Validation required -only single use of each number allowed in a text feild using Louts script
The field must be a multi-value field.
Call the function below in QuerySave like this:
continue = checkDups(fldname)
function checkDups(fname as string)
'doc is a global of type NotesDocument
dim item as notesitem
dim flag as integer, idx as integer
dim searchArray () as string
flag = True
set item = doc.GetFirstItem(fname)
'Loop through the values in the field
forall m in item.values
'Look for the value in the search array
if idx > 0 then
if ArrayGetIndex(searchArray, m) > 0 then
messagebox "Error: Too many " & m & "'s"
flag = False
exit for
end if
end if
'Dynamic array, increase the size preserving the values.
redim preserve searchArray(0 to idx)
'Save the field value in the array.
searchArray(idx) = m
idx = idx + 1
End Forall
checkDups = flag
end function
Note: I did not test this but it is pretty close. Essentially each value in the field is stored in an array and then the array is used for searching.
Subject: RE: Validation required -only single use of each number allowed in a text feild using Louts script
shame is has to be in script since it would only be one line of code in @Formula
@If(@Sort(fname) = @Sort(@unique(fName));@Success;@Failure(“Failure:yadiyadiya”))
