Using xPages after 10 minutes in designer appear grey screen
After 10 minutes, when i try to change some property of a view element (for example width, height…), appear a grey screen.
Following steps is one of more ways to reproduce my problem:
  • open designer
  • open custom control with a view element
  • edit some property (width, height). in this step for any char that i insert in editbox property, i wait about 5 second!
  • refresh page on firefox
  • back to designer
  • edit width/height units (from pixel to percent) of view element or edit margin/padding property of view
  • designer remain blocked 10 second and after appear a grey screen
  • moving mouse appear and desapper some element of designer
  • i must close and reopen client and designer, to continue to work (for other 10 minutes).
I try to unistall and reinstall, but nothing changes!
Windows XP Professional SP3
2GB RAM
Any ideas??
thanks in advance
Subject: How long did you wait before killing Designer?
  • I routinely see DDE lock up for over a minute before responding to anything. If you waited near two minutes this probably doesn’t apply.- Hope this helps…
Subject: RE: How long did you wait before killing Designer?
I wait over 2 minutes before killing Notes and Designer.
I don’t understand what “doesn’t apply”.
Subject: You waited over 2 minutes…
… so nothing I typed applies. (grin) Sorry I couldn’t be more helpful…
